1. I gathered from this forum that the king rear shock is a step up from the stocks as far as load holding. what would be the next step up without using shock spacers in the rear? does king make another shock that would make it even more load holding? at what payload did you feel the need to add the spacer?
3. In regards to the front end is there a king shock to replace the stock front spring? I know that it does minimum duty based on the TB's carrying most of the load. But based on Slees guide he says something inregards to the whole package springs included. You recommend sticking with the stock units, but if one were to go about upgrading that any recommendation you would give on what direction to go as far as replacements. I do intend to go full armour minus ballistic protection... with rack awning and water system.
I'm thinking of the same thing for my LX, but got a little bit confused while researching.
Please excuse me for a stupid question. What is the purpose of this lift? Will it give me more ground clearance?
My understanding is that it lift up the body, which improve the front end clearance since it's IFS, but the rear end clearance stay same because of the live axle? However, this lift makes it possible to fit in the larger tire which increase the ground clearance. Am I right? If so, what tire size, ie 33", should we look at with a ~2" AHC lift?
Please forgive me as I knew the info spreads in the threads. I think it might be helpful to have all related info into the same thread.
Thanks! and Happy Holidays!
Did you not read the entirety of this thread? 1 and 2.yes any lift will give you more ground clearance. 3. it raises your stock suspension mounting points, it is a set of 4 AHC or any shock really mounts for front and rear. The height will not change until you adjust the height sensors. You will need the new springs for the rear and adjust loading on the torsion bars. DirtDawg tells you the gains possible with this setup as far as how much lift front and back. 4. you can fit 33" tires without a lift that is also in the forum and I can vouch for fitment I have 33" tires. 5. most all of this information is held in these 11 pages of forum gold or a link or description of who or what to look for so I dont know how you missed it.
A 33.2" tall 275/70/18 tire will fit your stock vehicle. Here's my truck when stock with 275/70/18s in low, neutral and high mode. Only rubs in low mode.My goal is to increase the min ground clearance for at least 1.5", while maintain the factory room as much as possible.
From my research, the only way to increase the min ground clearance is to increase the tire diagram. The factory tire I believe is 31", and so at least a 34" tire is needed to increase the min ground clearance by 1.5".
The (front) tire has 3 movements: rotation, turn, vertical. Larger tires will impact all 3 movements. So the lift should take care of the change on vertical movement. For a LX470 with AHC, AHC sensor lift is easiest way to get 2' lift. However, the simple AHC sensor lift just reduce the height adjustment room (for increase) by 2" which doesn't meet the goal of maintaining the factory room.
- I don't think lift will increase ground clearance. It lift up the body, which improve the approach/crossover/departure angle, but the min ground clearance stays same at the bottom of the "pumpkin" of rear axle.
I believe it's also the intention of OP and why DirtDawgdecided to do the suspension spacer lift. In this case, the lift was actually done by the AHC spacers, while the AHC sensors were moved to accompany the change of body height to maintain the factory adjustment room.
I believe this is exactly what I'd like to do, as it preserve the capacity of AHC.
It doesn't matter if it slightly rubs in low mode. You wont be driving it like that.Great info. Thanks for sharing! Good looking white. I love white especially under Arizona sun.
For the rubbing at Low mode, I'd think a more negative offset wheel should take care of it?
Actually another question. I assume you carry the same size of spare tire. Does it fit in the spare tire well? How tight is the fit? Thanks!It doesn't matter if it slightly rubs in low mode. You wont be driving it like that.
it will fit.Actually another question. I assume you carry the same size of spare tire. Does it fit in the spare tire well? How tight is the fit? Thanks!
Great info!it will fit.
I've put thousands of offroad miles on my stock LX with those tires. I see no need to lift mine as it raises in 4Lo and is a DD. Go put a few miles on it and see what you think you'll need.Great info!
So basically a 33.2" 275/70R18 gives a 1.1" actual lift at the min ground clearance, comparing to the stock 31" of 275/60R18, which is pretty close to my goal of at least 1.5" increase of min ground clearance. Sounds like I should invest the money of getting another 0.4"~0.9" to something else, if the another 0.4"~0.9" doesn't really make big difference on the offroading capacity. Any experience or recommendation?
To clarify, my primary purpose with this LX470 is to go places, remote and wild places solo most likely, on established trails.
For your expressed purpose, 33" is fine. The AHC high and extra-high settings will easily get you through anything you're likely to come across. The differentials are the lowest part, but they are cleverly offset to avoid the usual hang ups. If you do need additional clearance it will probably be in the way of more approach/departure angle.Great info!
Good idea! Will try out stock setting with larger tires first before calling for lift.I've put thousands of offroad miles on my stock LX with those tires. I see no need to lift mine as it raises in 4Lo and is a DD. Go put a few miles on it and see what you think you'll need.
Good to know. How could you enable the "extra-high" setting? Didn't see it on the switch although. Is it something automatically when you put into 4Lo and/or enable CDL?For your expressed purpose, 33" is fine. The AHC high and extra-high settings will easily get you through anything you're likely to come across
It's automatic. If the t case is in 4lo, the AHC is in H and one of the wheels freewheels, the AHC automatically raises up an extra 30mm and 20mm in the front and rear, respectively.Good to know. How could you enable the "extra-high" setting? Didn't see it on the switch although. Is it something automatically when you put into 4Lo and/or enable CDL?
Great! I'm in love with AHC and won't mind renewint it when it fails in the future.It's automatic. If the t case is in 4lo, the AHC is in H and one of the wheels freewheels, the AHC automatically raises up an extra 30mm and 20mm in the front and rear, respectively.
