1KZ-TE cooling issues
knoxville, TN
My 1996 Prado is a big ass mess with a blown head gasket (confirmed by a mechanic who did a smoke test?-I think). But no white smoke and no over heating. I drove it a short distance today and noticed it wasn’t consuming coolant like I would suspect for a vehicle with a blown head gasket. Turns out the top radiator hose is hot but bottom is not (as well as the bottom of the radiator was not hot). The coolant was nasty. I flushed it 3 times but still the same problem. I ran it with out the cap and rev’d the engine. This would over flow the radiator into a funnel. So I assume the water pump is working. I’m guessing the radiator could be clogged in places from the nasty gunk that was in my overflow reservoir? Dunno, kinda at a loss.
Simple enough to remove the radiator and have a shop test it. If it needs replacing check out my build thread, there is a link to where to buy a replacement radiator.
Gotcha, makes sense. I may drain everything and pull the thermostat and do the boil test. And fill it back up and run it with out the thermostat to see if the bottom hose gets hot then.
I pulled the thermostat today. It’s not an oem thermo. It’s a modorad thermo. Boiled it on the stove and it opens at 89 degrees Celsius. Maybe this is why my bottom hose was cold? During my short drives it’s not getting hot enough? Gonna order a 76 degree thermo and put on there. May take radiator off and have it serviced.
Lot of crusty/rusty debris in the top radiator hose.
Got my rad off. Having it flow tested next week. Probably gonna order a water pump cuz I’m betting the pump is bad. If not I’m gonna replace it when I do the head gasket.
I didn't use a bleeder when I did my water pump, went fine? I have a PDF file of a rough scan of the engine handbook, I don't remember if it states that there's a bleeder.
Lot of words to say "I don't know."
Engine handbook can be found on Google or I can send it to you.
Edit: Let's see if this works.
Oh yes, I have that pdf open on the web. Thanks for the pdf. I was just being lazy and asking so I would have to do the work myself😁
Here is what I would do.
1. Buy your own Exhaust gas detection kit. Don't trust that's what the mechanic did.
2. Run distilled water until you are positive your cooling system is healthy and everything is resolved.
3. Have your radiator inspected.
4. Do not trust your stock temp gauge. Are you sure it is functioning?
5. Start inspecting all of your houses and clamps
6. make sure your overflow res cap is facing the right direction.
Hey KnowBuddy, thanks for the help.
1. That sounds like a good idea. The mechanic did give me a video but it’s hard to tell conclusively that it’s coming from the head. I was gonna have the oil tested once I got it running again.
2. Flushed it a lot.
3. Radiator getting inspected tomorrow.
4. Gonna put in a temp sensor-already has a guage in the cab for, boost, egr, and temp. Temp was not hooked up.
5. Been doing that
6. Never heard that one before but I’m game for anything. It was empty and crusty when I bought it-I didn’t do the best inspection.
Thanks again!
I just noticed that it looks like the water pump has 2 part numbers. One with just the front section (16100) and one with a rear cover (16110C). Any reason why I couldn’t just order 16100? And are there any domestic market Toyotas that used the same WP. Thanks
Going from memory here, when I did my water pump the kit I bought came with the cover. Glad it did, my leak turned out to be the gasket between the block and that cover and not anything to do with the water pump itself.
If you skip the cover, definitely still get the cover/block gasket.
Ok that makes sense. I will probably just do the whole thing.
I opened up the water pump (just the actual pump part). I can’t tell that there is anything wrong with it ( new one doesn’t get here til Thursday). I am thinking that maybe the pump was not turning because the belts were loose? Could also explain why my batteries aren’t charging? I’m going to try to hook up the temp sensor, put all back together and see if it pumps the coolant. Also putting in a 76 deg. Thermostat and a 10 fin fan.
I had this happen on my 61 but it was because my ac compressor seized. So the belt was holding everything up.
Not turning would do it.
Proper reassembly is too much PITA and good cooling is too important, if I had it torn down I wouldn't even consider reassembly without installing new parts. New timing belt and tensioner, whole nine yards.
I’m going to do all that when I redo the head gasket. I’m just trying to get the cooling sorted to limp it a long for a month until I have the cash and access to another car.
