If it makes you feel better, mine are the same way. 10/12 are not in spec, and most are too tight. I put the transfer case shifter to neutral, but from what I learned since posting the original is that the automatic transmission should be fine to hand crank in park. I'm not a mechanic so I just wanted to make sure that was the case. The service manual doesn't mention anything about being in a certain gear, regardless of the type of transmission.
I haven't done the valves yet, and the engine seemed to be a tad too noisy even for a diesel, so I'm hoping this fixes that concern. With 10/12 not being in the right range of clearance, it should help regardless of the noise afterwards. In the middle of a lot of maintenance work so I won't be able to test drive or anything for a bit longer.
