JDM Journeys
Moderator
If all checks out with glow plugs I'd be looking for air in the system by using a clear fuel line between the filter and the pump
TrueSo do I read this as saying you have a Wilson switch installed and you hold the button?
I agree with you. It is more probable.If all checks out with glow plugs I'd be looking for air in the system by using a clear fuel line between the filter and the pump
Just today, I stumbled across a guy explaining in detail what can happen if your head gasket is deteriorating. It also contains exactly the symptoms you decribed. Maybe check it out?
