I love the idea of a supercharger. No question supercharged diesels make plenty of low down torque, and would make a big difference to a sleepy 1HZ.
Modern turbo charger can do the same, but better, and does everything else better.
Note, that advert dates back to 2012, and sprintex supercharger way longer than that. Old inefficient 1950s technology, roots blower.
The reality is, there's far more disadvantages with a supercharger vs modern turbo charger. Dollar for dollar, turbo charger has better bang for buck overall
I started nutting out how to fit an Eaton m90 supercharger, and compounded turbo on a 1HD-T about 10yrs ago.
I had the supercharger, and turbo, and started drawing adapters, calculating drive ratios for pulleys, and sourcing parts.
The more I looked into it, the less appealing it became. I also looked at sprintex offerings too. The unit recommended for a 1HZ was too small IMO. They are a roots blower, extremely inefficient
About the only selling point for a supercharger is torque from idle.
I recently fitted a 1HD-FTE turbo to my HZ, it boosts with loads of torque from around 1200rpm.
The 1HZ is a high compression engine that has pretty good torque from idle. on road, the torque below 1200rpm really only comes into play on 1st gear at sub walking speed (take off from standing start, or parking etc) They have a reputation for having good torque for crawling road.
A turbo has completely transformed my 1HZ, and I went a budget, used OEM turbo. A more modern turbo has even more potential.
Heat from a turbocharged system comes from two things.
burning more fuel to make more power.
Compressing air generates heat. The more efficiently you do this, the less heat is generated.
there's no such thing as a free lunch. Supercharging also needs fuel added to make more power.
Supercharger also compresses air, but does it at far worse efficiency, so generates more heat which is added to the combustion cycle.
No doubt a turbo creates more radiant heat in the engine bay as hot gas passes through, and heats the turbine housing before it can escape out the exhaust.
