1HZ Injection Pump driven gear
Ventura, California
Website
ardnez.com
Question, if i decide to replace the injection pump driven gear, do i have to remove the other gears as well or can i remove and replace just the one gear?
Pretty sure it is, but you will have to remove the timing belt. I used a steering wheel puller to remove the gear.
timing belt is removed, but
timing belt is removed and so is fuel injection pump, but i need to remove the injection pump gear ⚙️ because 2 bolts that go into the gear to hold the camshaft were damaged when i used a puller to remove the injection pump so now u cant bolt it back up unless i remove the gear and replace it
