Hey all. Got an issue with my 1HZ with an aftermarket turbo. 320,000km on the motor about 80,000km with the turbo fitted. Running 10psi non intercooled.
Issue being that for a while i've had a flat spot on acceleration in second gear, up around the 3000rpm mark like it's running out of fuel and then coming good.
Changed the fuel filter about 6 months ago and couldnt get the primer to pump up hard all the way, but it still started no problems but has had the issue still.
2 weeks ago i bought a new primer pump and i thought i'd fixed the issue for good. Primer pumped up nice and hard, and it started first turn with no long cranking like i'd been experiencing previously.
But about a day into having the new primer pump on there the issue resurfaced. Popped the bonnet to check there were no leaks and found that the bulb on top of the primer was soft and took 3 or 4 good pressed to get it back to hard, drove away and the issue was gone.
So my wonderings were - has anybody had a similar issue before and how was it resolved? And my brain has forgotten at the moment, but should the primer bulb be hard at all times except for right after you've let air into the system to change filter etc?
Thanks in advance
Thanks in advance
