I'd like a second opinion and some advice. First, some background. I have a HZJ80, which has never had a turbo. The 1HZ engine has an aftermarket head, which was fitted new around 7 years ago and built by a reputable shop, after finding there were cracks in the original head from an earlier overheating event (occurred about 2 years prior, symptoms weren't obvious immediately). Injectors and pump were done around 5 years ago. Engine has 498,000kms as of today.
So I last did my valve clearances about 18 months ago. I didn't keep records, but I know a few of them were badly off. They hadn't been checked since the head was replaced, so without a baseline, I just brought them all back to spec and I've been driving it since then. About 10 months ago I moved from about 30m elevation to around 700m elevation. After this, I noticed an increase in black smoke under load, which isn't entirely unexpected given the elevation change, however I'm frequently driving from 700m to 900m up some fairly noticeable slopes, so this dirty exhaust condition has been happening quite a bit. The black smoke may have been getting worse, but it's hard to measure that kind of thing, and maybe I'm just more aware of it than I was originally. More concerning to me is that on the last oil change (about 5 months ago) I noticed the oil was much thicker than I've seen before, which, correct me if I'm wrong, is probably due to increased carbon from the dirty combustion I've been running.
So I've been poor on time (and, well, just poor in general), but this weekend I finally got new parts and time set aside to do the filters, timing belt, brakes, and a full tune-up. First thing I did was take some compression numbers (actually, took these last weekend):
1 - 440psi
2 - 445psi
3 - 455psi
4 - 458psi
5 - 468psi
6 - 449psi
These are from a hot engine. Specs say the range is 384-520psi with a max 70psi spread, so for an engine with half a million kms on it I think those are reasonable figures, although other opinions are welcomed. A full bottom-end rebuild is something I do plan to do with this engine eventually, but with those numbers, not something I'm looking at doing today. Next thing I did was change the air and fuel filters. I fitted some clear hose to the injector pump just to verify I'm not getting air in the lines, which I haven't had symptoms of, and it looked good, no bubbles. Oil filter/oil change is pending, because I wanted to check the valve clearances first.
So I removed the rocker cover and took clearance measurements on the valves. They're not so good. Clearances are as follows:
Factory specs say the range is 0.15mm - 0.25mm for intake, 0.35mm - 0.45mm for exhaust. The intake numbers show a mostly even nominal drop, and they're out of spec, but it's possible I did a dumb thing and set them to the minimum clearance values rather than shooting for the middle or upper. Can't recall. The exhaust clearances though.... assuming I didn't massively screw up when I did the last adjustment, the exhaust valve clearances, apart from cylinder 4, are all WAY off.
What I'm debating now is, do I try and bring them back to spec and button it closed, or should I be pulling the head? What worries me is that the valve shims I'd need to fit are WAY out of factory range. According to the FSM, shims in the range 2.35mm-3.30mm are available. I pulled exhaust shims 1 and 2 to measure (ran out of light for more), and they came up as 2.36mm for the both of them. At those values, I'd need shims that are 2.00mm and 2.24mm thickness, respectively. I don't have any that thin, nor do I think sourcing them would necessarily be the right move.
I'm wondering if I have burnt valves, or just otherwise gummed up exhaust valves which are caked with crap and not sealing tightly as a result. Does this sound likely/possible? I was planning to check the injectors to see if they were all healthy, or if they were contributing to the smoke problem (along with checking injector pump timing), but now I'm wondering if the black smoke is actually a result of exhaust valves not sealing properly. Wouldn't I have measured worse compression numbers if this was the case though?
I'd like some advice before I go nuclear and pull the head. Any thoughts guys?
1 - 440psi
2 - 445psi
3 - 455psi
4 - 458psi
5 - 468psi
6 - 449psi
Cylinder | Intake | Exhaust |
1 | 0.14mm | 0.04mm |
2 | 0.14mm | 0.28mm |
3 | 0.15mm | 0.15mm |
4 | 0.14mm | 0.35mm |
5 | 0.16mm | 0.23mm |
6 | 0.12mm | 0.22mm |
