I have a 1HZ engine in my Land Cruiser BJ70 that has a coolant leak in the cover of the block mounted oil cooler. The leak is directly behind the fuel injection pump and just below and to the left of the top nut (of the two) where the u-shaped oil cooler pipe is attached inside the cover. I am in Costa Rica and a new oil cooler cover is not available here so I have ordered one through the local Toyota Dealer from Japan that will take a month or more to get here.
I am thinking about a temporary fix so I can drive the vehicle for the next month. The hole diameter is about 1/4 inch or 6mm, quite sizeable.
I have tried to photograph the hole but it is a spot that is very difficult to photograph.
I do not have access to JB Weld here but there are epoxies from Loctite available that can withstand 110 deg C. I was thinking about using a cut off bolt to partially block the hole and then applying epoxy over it. I am hoping that someone else may have encountered this problem before and has a better solution.
Thanks in advance for your assistance.
