For Sale 1HZ/1HDT Air/Water I/C Complete Setup
San Diego
****SOLD****
I have A/W intercooler setup for sale that I have pieced together consisting of the following:
-Frozen Boost Type 24 barrel I/C, similar to the type Denso uses.
-Denso inlet and outlet pieces that make the I/C an easy install
-Moroso expansion tank, with a custom bracket I made that allows it to bolt up to the side of the intake.
-SPX Flow johnson 24v CM30 pump, with a bracket that mounts it to the inside of the frame of a 70 series.
-Custom radiator that I had made designed to mount on the bottom of my ARB bumper horizontal with the ground, along with an air dam to better direct the flow. This did not work very well, but with the 70 series there is not much room to mount anything in the front, so I gave this a shot. I would recommend a different setup for the radiator, but even with this setup it lowered my EGT's 100-150F.
This took me a while to piece together and is virtual a bolt in setup, aside from the radiator.
I will sell everything for $650.
Very interested. Can you send me dimensions for the radiator so we can do a cardboard mockup? This would go in a HDJ81. Thanks
Here is the drawing that the radiator was built from.
Thanks. I'll check it out when the wife returns with the rig on Friday.
