Yes ATA has less parts and is generally more simple in its design. Im sad to day, but instead of blocking your radiator with an ATA intercooler, you will be doing it with a second radiator for your WTA cooler. I guess you could do a top mount radiator. There was enough room up there for my ATA intercooler, so why not a radiator?
I have my W2A radiator as pictured below the radiator so it's not blocking it, and working well. The radiator is a german KTM unit.
W2A are not short duty cycle. I'm not sure where that comes from-maybe the icebox dragster setups.
If the system does not have enough fluid, too small a radiator, or otherwise ineffecient than yes, it will heat up the coolant and not be able to cope. This is the same as a engine coolant system - too little fluid and it won't recover fast enough.
Many OEM systems have W2A IC's when performance counts,not dollars.
I think that's part of the fun/challenge to set it up right. Here are some parameters
http://www.enginebasics.com/Advanced Engine Tuning/Air to Water Intercooler Design.html
*I think you have to note that a too small A2A IC and /or improper piping will also make for a poor system.
It's been important for me to keep my pre and post IC temps monitored and compare the delta to see how well the system works.
That is really the only way you can tell how well any of these systems is working, I suppose.
Yes it's been a fun project and I have re worked my system a few times to improve it.
I think it's great and I'm constantly picking up new tidbits, such as this thread with other IC users
