There you go guys. Go for it. I'm cut and pasting some simple results.
21psi boost
12x12x2 heat exchanger with fan
All my test data from this setup is with my max boost at 21psi, and I'm always at sustained max boost and thoroughly loaded if I'm trying to collect data...
My water seems to stabilize about 30C above ambient air temperature. It takes a couple of minutes to get it up there but it will hold forever once it's there so I'm certain that it's stabilized.
Average temperatures (in Celcius) during heat soak:
154 pre IC air
76 post IC air
54 post radiator water
23C ambient air
21psi boost
154 pre IC air
76 post IC air
23C ambient air
