Tapage
Club 4X4 Panamá
Ok lets start ..
1. Pyro = Pyrometer = gauge that reads EGT ( exhaust gas temp ) that it's a pretty acfcuracy reading of the temp on your pistons ..
2. Max Safe temp on your pistons 1250 ºF ( more than that= melted pistons )
3. Proper fuel / aire ratio keep estequiometric mix 14.5:1 it means yuu can't goo up more far from 1250 ºF at any driving condition ..
4. Usually, black smoke in your exhaust means more diesel in the chamber than the engine can burn ..
5. Usually more boost with proper amunt of diesel means more power .. you compensate fuel with boost ( that means more air =0 Oxigen in the chamber )
6. More than 14 PSI usually iin our Toy aplication require intercooler, and you must need to check the turbo map to see when ( at which point ) your turbo goes out of the performance islands.
7. More boost = more compresed air = more heat = less Oxigen
