denis
(O) toyota nut (O)
I modded and "de-crimped" the exhaust on a friends 80 and there was not much gain, if any. I don't believe the torque restriction story, all toyota diesels are starved for fuel before anything else.
Hi Martin.
Do you have an EGT gauge?
That'd tell an interesting tale.
The truck boosts faster, is WAY more responsive to throttle, and EGT's appear lower by about 100F under load if not more.
2H it's a IDI and the 12H-T it's a DI engine .. huge diference .. Anycase I was so scary to put 27 psi in any toyota engine with stock internals ..
To get that big an increase, there must have been something badly wrong with your old exhaust.
Aeroturbines don't work, it's not that.
Do you run a boost gauge? If so has there been an increase with the bigger pipe?
You're only going to get an improvement if your current system is really restrictive.
Measure the backpressure after the turbo and see what it is.
Anything less is guesswork.
What about the turbo seal? I thought that exceeding 13 PSI would blow the seal (causing oil to be pumped into the intake manifold)
IDI = indirect injection; DI (which I think you transposed) is direct injection diesel engine.
can let me know what mean of IDI and ID ??? thanks
I'd move!
Aluminized pipes can last for a long time. If you don't have the cash to pony up for SS, you can paint your exhaust with high heat paint each year.
Also living in salt belt you should be having your truck oiled each year.
Indirect Diesel Injection vs Direct Injection
mean direct injection is more power full?? now i still finding information about modify the fuel pump, to race spec or more fuel will inject to engine and bit higher RPM power
More fuel will give you more power throughout the whole rev range. But too much can melt your pistons or blow black smoke.
It's a good idea to get an EGT gauge (if you haven't already) so you can monitor what's going on.
Yes direct injection is more efficient and more powerful. But it's also noisier than IDI, kind of a grumbling sound.
hehehe soon i'll get EGT, not now.
now the engine also blow a lot of black smoke
, but still not efficiency
too bad ..
Probably it means you have plenty fuel and not eouight air to burn it and produce power ..
I thought you need to read plenty about diesel and turbo engines.. this statemnt confirm my teory that you have not eought aire right now to burn all diesel that you have in the chamber ..
Boost gauge, Pyro gauge and air fuel meter are a must to proper adjust your engine at " hight " performance ..
too bad ..
as u can see, one is fuel one is air, so fuel is fuel pump. then the air is how?? turbo?
