Completed the timing belt change( Not 1st timing belt) went to turn the motor by hand to ensure everything was going well and the motor would not turn by hand (pry bar)
Tried turning by hand again, it felt tight so I pulled more, used more force, something gave way. I crack, a release, something. Like a tough bolt releasing from torque.
I buttoned up the job and started the vehicle.
Video result
Checked the job over and all is correct. Placed transmission in neutral, transfer case out of gear, removed glow plugs (need new glow plugs)
Tried turning by hand again. Now i have 1\2 turn on the crank pulley and that's it, it will not move either way any more.
What would prevent the motor from turning by hand yet still allow the motor to start and run? And based on the explanations above why is it out of time?
Trying to get the motor to TDC to ensure i haven't slipped a cog.
Video result
