Yes, I've read that one. It's pretty good but it's still not exactly like our pumps. Specifically, the off-boost adjustment on top of the boost comp cap. Once you take the top off the boost compensator you will see why I don't like the LCOOL directions. When you back off the jamb nut and turn the set screw what's actually happening on the underside of the cap is a tapered piece is rotating. It neither moves up nor down. A full 360 degrees will return it to its exact same original position. The way the LCOOL directions go, they say to turn it in 1/2 turn increments. Great. So you could be going from max to min, or min to max, or 50% to 50% or anything in between. The next 1/2 turn you do will return you to your start position. It's possible that the 1HD-FT has a different cap than the 1HD-T but that's not helpful to me or you.
Here's a couple more that are well worth the read, particularly the first LONG thread....
Toyota 4WD Surf Owners :: View topic - 2LT Boost compensator
Bosch VW Type INjection Pump Governor Operation
Also keep in mind that when people erroneously refer to the main fuel screw as a "max" fuel screw, it's confusing. The main fuel screw moves the ENTIRE fuel curve up or down. That's why your idle changes when you play with it. That's also why it's a necessary part, but only
part, of tuning the pump.
Assuming you're dealing with stock boost levels, my suggestion is to dial the main fuel screw to a point where your EGTs can't go over 1300 at max boost. Then turn your off-boost up or down to get a good compromise between off-boost response and smoke.
I wouldn't bother rotating the boost compensator rod at stock boost. It's an eccentric cone but the taper angle is the same all the way around. Rotating it will give you very similar results to playing with the main fuel screw.
Turning the star wheel inside will put more or less preload on the boost comp spring. At stock boost levels there's no need to tighten it but you
may want to loosen it. This will allow fuel to get added more aggressively as you make boost. If you notice too much smoke in the 5-9psi range you've gone too loose. They say to only go about 3 clicks but that's not very much. Don't be afraid to go a lot more but I recommend keeping notes. BTW, it's much easier to keep track of if you do it from the top (with the boost comp cap off) instead of through the side hole where you can't see what you're doing and can't make reference marks.
The Surf Owners link I gave is really good. I think there was also a picture of what our boost comp rod actually looks like. The important feature not pictured elsewhere is that ours tapers in then has a straight section, then tapers back out. On mine anything above 12psi would result in fuel cut (a handy protection I guess?) Going to high boost and actually being able to tune a good fuel curve requires you understanding the whole setup well. You need to modify the rod,
tighten up starwheel, get silly with the main screw, and allow the rod to ride higher off-boost so you're not smoking out the whole neighbourhood driving around town.
Have fun!
