1HD-T Water Sensor thread size .. (1 Viewer)
Tapage
Club 4X4 Panamá
Panamá
Website
www.4x4panama.com
Hello folks .. any of you know for sure which it's the thread size / pitch for 1HD-T / 1HZ water sensor ..
I'm guessing by eye that it's close to 5/8 what ever it should be in British thread that Mr. T use ..
David
David
It will definitely be metric.
I have a bad head around, I can check on the weekend if you still need it then.
My guess is 14x1.25 or 14x1.5.
cheers,
jan
All pipe threads on the 1HD-T are BSPT.
It's the same sensor/thread in the head from the 3B over 2H, 1HZ to 1HDFT. Likely different part numbers, but they all cross over (if they are 12V). I doubt they are pipe thread, but I do not know.
thanks,
J
Edit: 83420-20020 is used in hundreds of models...
yes please .. no rush tho .. just wanna put a T on one of those ports to add a digital real temp gauge ..
%255BUNSET%255D
Is this the sensor that goes into the engine block or the outlet pipe for the top radiator hose like the australian models?
the ones going ( there are 2 and both the same thread ) on the outlet pipe top radiator hose ..
Not sure of the thread size ,but I used a 3F sensor on the 1HZ top outlet pipe .So the thread is the same there also.
