Dilspec
- Location
- United States
Delete.
You wont be able to use the dump pipe, Im certain of that. You can buy CT26 exhaust flanges of eBay, best to use that.
I dont see too many 13BT CT26's, they are quite rare and if any turbo was not the right spec on a Toyota Diesel it is the CT26 on the 13BT. Of course, it is much better on the 1HDT. On the exhaust housing it probably has 58010 cast into to turbine flange where it bolts to the exh manifold; that is the same as the 11HDT. On the compressor side it will have an inducer between 41.5 and 43mm. 1HDT are 43mm. I *think* the 13BT is 41.5mm like the early (Gen1) 3SGTE motors.
Hope that helps. Cheers
