Nope.... it doesn't work this way. Because after nozzle is opened, pressure defined only by plunger efficiency, since the liquid is not compressible.
I am talking about exactly the same thing. So plunger head (with 4 pcs) from FTE much more efficient compared to the single 12mm plunger from FT, and it CAN inject the bigger amount of fuel for a shorter time. As a result, on high power output modes and high RPM, it resolve a problem with extensive exhaust, which I received from a long-time injection of a single 12mm FT plunger, since I've increased fueling on my pump. As a secondary result, small turbine outlet 48mm of FTE CT20B becomes a major restriction with 1HD-FT tuned fuel pump. In my case, I started to feel that restriction after 85-90 Mph and 3000-3200 RPM. Factory CT26 turbine from 1HD-FT has 52mm outlet - feel the difference ). However, this factory CT26 wheel is too big and heavy for the low-end rpm response - 68/52. That is why I've decided to go with smaller Celicas CT20B, which has 60/50 turbine wheel and works good at low-end and still at high-end around 3400-3600RPMs.
No, I don't want it, since I have H151F + 3.7 axle ratio (41/11) + 33" tyres. So, in this config, the gearbox has a very good balance power/speed. I have 120km/h (75Mph) at 2600 RPM - about maximum torque, and 140 km/h (87Mph) at 3000 RPM. Pretty convenient and still have a power reserve for overtaking.
