1997 Cruiser - Parting out
Did you end up selling those headlights?
Thank you!
Did the front power seats work? I need the front mechanical adjustment bars for both seats that adjust the seat sliders." The white plastic housing and rods and motor across the front of the seat to the other white plastic housing on the other side of the seat on both seats. Are these still good? I also need a passenger seat bolt.
Looking for a computer and a coil ignihter for a 96 Land Cruiser. How much to 86004 AZ
the main truck computer is behind the glove box to the right, here are some photos of the other part I want. the ignihter is located to the right of the master shown in photo.
Sethro
Thanks
Sethro
I need the rear steps going back to the 3rd row seats, including the plastic screws that hold them down.
Also need both rear ashtrays.
Thanks
Rusty
also need passenger side tail light
Rusty
need rubber air intake hose
need rubber air intake hose. PM sent.
I am interested in:
Sun visors (both) good and working.
Back frame of the left rear slide window.
Antenna switch up-down (97).
CDL switch, if you have it (97).
Center console (97) with top arm rest.
Please, PM me how much to 77095.
Thanks.
Rear driveshaft? If it is unlocked I'm interested in the rear third member. Transfer case and steering gear box too.
Would you have the rubber for the window channel? I need the front passenger side rubber that the window slides in-between. Its the vertical rubber that's closest to the b-pillar ?? Mine is a 94 but I'm guessing its the same for all years. I was told it just pulls out.
Thanks
Kevin
Need a passenger side rear door lock actuator. Pm'd you
I am looking for that black plastic insert that clips into the dash above the factory radio for a 95-97 80 series.
I broke mine so am looking for one that is still in one piece, with the tabs intact.
Do you have one available? Thanks
email sent
