Wanted 1997 1fz-fe
I agree that would be a Sweet rig, I have the 1FZ-FE motor you are looking for in my garage. looking to find a H515F (with everything) to bolt up.
not having much luck. More $$$ fixes everything
Missed the H55 with all the necessary components earlier this month.
you really should consider the FJco bellhousing for the 1fz / h55f. the eqrly h151f had synchro issues and command a higher price than a brand new $2500 h55f thst you can get here at any toyota dealer. and while the h55f is not as strong as an a442.....you will need to plan on servicing the h55f in the 150k mile range to be safe and not hurt the case. so local parts availability will be key advantage vs the h151f
I may be selling a backup 1fz i have that the p.o. had a brand new oem shortblock from Toyota installed. It has 80k documented miles and receipt for the $6000 that the dealer gouged her for. I pulled the head which the boneheads didnt do and had burnt a valve. the head went to the machine shop and is brand new rebuilt and still wrapped up. So effectively youd have an 80k mile bottom end and a brand new top end when put back together. I left the head off just in case i decided to sell it.......as someone can view the perfect cylinders and block surface which has no headgasket pitting.
I will know soon if i am scoring a 200 series in which case i will be offloading all my 1fz stuff.
Thanks! I'm interested...
Ready to go, just need to bust the trans loose.
