Trade 1995 Lexus LS400 Ebony Teal Pearl w/Ivory Leather 4.0L V8 260hp 158K $7000
Sold
1995 Lexus LS400 Ebony Teal Pearl w/Ivory Leather 4.0L V8 260hp 158K $7000 NO RUST!! Check the underside pics.
Pics - 95 - LS400 Ebony Teal Pearl pictures by 7schulz - Photobucket
I have all receipts (about an inch worth) from Tom Wood Lexus of Indianapolis, where it was bought on 12/94 Original window sticker $57,653 - Paid $62K
I'm the second owner. All Options including Traction control, 6 disk CD player and Nakamichi Prem Sound and heated seats, the cell phone is still in the car.
Brand new tires Eagle F1's $500-600 and OEM 2005 LS430 Sport 18 inch rims (Very hard to find and expensive). Price would be $6000 if you didn't want the new rim/tire combo and I put the original rims back on. Both sets of rims and tires come with car along with 10 Oil filters
Bad
3 spots about the size of a 50 cent piece where the clear coat is pealing.
I unplugged the telescope motor(stopped working and didn't want to burn it up) on the steering wheel, once I moved the steering wheel where I wanted it. It does go up and down normally.
$7000
Here is the maintenance since purchase from my spreadsheet.
1995 Lexus LS400 Maintenance
VIN# JT8UF22E3S0005795
Date Mileage Maintenance
12/30/2009 153,300 Purchase
1/1/2010 153,300 Amoral Leather Interior
1/20/2010 153,600 Air Filter
1/23/2010 153,667 Lexus Battery(Tom Wood)
2/27/2010 154,000 Strong-arm Hood Struts
3/20/2010 154,500 LS430 18's - Good Year Eagle F1 GS-2
4/10/2010 155,000 Oil Filter 6qts M1 0w-40
4/10/2010 155,000 Start conversion to Syn ATF 2qts M1 Syn ATF
4/10/2010 155,000 Drain - Top off brake, PS Fluid
4/10/2010 155,000 Clean and scrub throttle body and intake plenum
4/29/2010 155,500 Cabin Air Filter
5/15/2010 156,000 Updated ECU and Cruise Control Computer
5/26/2010 156,200 Leatherique all Seats
5/29/2010 156,300 Window Tint All Windows
6/26/2010 157,500 303 Aerospace Protectant
7/12/2010 157,900 Rotate Tires
Major stuff done at Tom Wood Lexus
@ 133K a 30,000 mile service was done, trans and diff fluid, cooling system flush, bleed brakes, clean throttle body, inspect and lube.
@ 130K Timing belt
@ 120K 60,000 mile service was done, trans and diff fluid, pcv valve, fuel injection filter, platinum spark plugs, brake bleed, cooling flush, throttle body and fuel injector clean.
@ 109K power steering pump/pulley
@108K both cats replaced
@74K First timing belt
I have receipts starting at 1000 miles, and every oil change and maintenance work that was done and it's a lot, and original window sticker and sales receipt.
what is the largest tire size I can run without a lift? 33" or 35"?
:p
good luck with the sale. Those sure are sweet rides. Smooth like buttah.
Got the cruiser back, new 4.88 gears and ready to run. This car only gets driven in nice weather. Would really like an LX450 for a DD as I build the 93 for off road/winter. Cash or Gold is good too.
