Couple weeks ago our Land Cruiser started to misfire occasionally at idle, but would still run fine under load. Then it progressed to misfiring almost all the time at idle, and still usually fine under load, and then a few days later, misfiring all the time.
I knew the distributor o-ring was leaking, so i pulled off the cap to make sure the distributor wasn't filled with oil or something stupid. Found a VERY worn cap and rotor while i was in there, and some kinda suspect plug wires.
SO, i ordered plugs (NGK Vs), wires (NGK), cap, rotor, and distributor o-ring, since i couldn't get anything but the spark plugs locally.
Parts trickled in, i ended up doing the plugs/wires/cap/rotor before the o-ring came in. All seemed well for a couple days.
Wife has reported twice in the last 4 days that the truck has briefly misfired at idle only during her commute, both times midway. So, i'm not convinced that replacing all the badly worn ignition stuff has actually fixed anything, though it was probably a good idea anyways.
Things i've read across the internet (on this forum, specifically):
1) It's definitely my fuel pump (highly doubt due to random nature and only dropping 1-2 cylinders at worst)
2) It's definitely my fuel pump relay (see above, and it's not struggling to start at all.)
3) It's definitely a cooked engine harness due to EGR (Is this harness on intake or exhaust side?)
4) It's definitely my coil (Maybe?)
5) It's definitely a cracked intake tube (While not brand new soft and pliable, i saw no damage to the pipe when i did the ignition tune up, but maybe i should throw a new one at it anyways?)
Anything i'm missing here? I DID notice that the spark plug tube seals are leaking pretty good on 2 of the cylinders, but the random nature of it leads me to believe that yes i should fix this, but no it's not likely to be my issue.
It did throw a code a couple times prior to the ignition refresh, but has not throw a code either time it misfired post-refresh. The Code was 26, which appears to be "rich condition." This is what i'd expect with an ignition misfire.
