I’m considering sending mine in for repair again but I’d rather just buy another used VAF.
Or.... you can get a new OEM VAF.
NOT CHEAP.....
We talking NOS? How much because I would consider buying one if it's relatively reasonable.
Maybe I don’t want to know. But I do, what’s the damage? First and second borne? A limb? My balls? You’re gonna have to get those from my spousal unit.
Break the suspense and hit me with it.
NOT
If you are serious, contact me
I love the foreplay, but I'll hit you up direct.
Greg, I updated the post above to state all parts used are OEM, including the brake pads. I didn’t mess around with 100 series pads because I’m not convinced there is any gain with slightly more surface area. Probably none/negligible. If I get a 100 series I’ll get 100 series pads.Looking good. Enjoy that shiny caliper while you can. Will you share which flavor of rotors, pads and calipers you chose? I'm assuming the green pads are the Toyota flavor...
I mainly took apart the rear axle to inspect. Replaced all the consumables but the bearings and seals etc were in perfect condition. I have a new set already packed with grease sitting in baggies along with all the consumables. Maybe one day they’ll need replacing.That's exactly what I was asking, though I was curious about the calipers. Thanks for answering! Did you also rebuild your rear axle (new bearings, seals, etc?
As for the 100 series pads, I might try them next, but my understanding is that the pads are hard to install on brand new rotors anyway. I actually think time spent getting the LSPV bled and adjusted is where I really need to spend some time.
Don't do the 100 series pads on these.That's exactly what I was asking, though I was curious about the calipers. Thanks for answering! Did you also rebuild your rear axle (new bearings, seals, etc?
If you haven't, I recommend new soft lines from calipers to body. I have a similar pile of parts in queue and my lines look past expiration, so I grabbed them as well.Greg, I updated the post above to state all parts used are OEM, including the brake pads. I didn’t mess around with 100 series pads because I’m not convinced there is any gain with slightly more surface area. Probably none/negligible. If I get a 100 series I’ll get 100 series pads.
Already did it a few months back. Got the extended OEM brake lines. My wife thinks I’m the king of efficiency but only if she knew.If you haven't, I recommend new soft lines from calipers to body. I have a similar pile of parts in queue and my lines look past expiration, so I grabbed them as well.
Onur, I learned from the best! Besides, the cost difference between reman and OEM is not that great a gap. If I have the option, OEM it will always be. For those of you out there who will judge, yes, I’m an OEM fanboy. Sue meSmart longevity move by getting the new OEM parts versus the reman parts.
Solid.
