I need a VSS. It's the speed sensor on the tail end of the transfer case. I can send you a pic if you like. Let me know if you have one and hoe much. Thanks.
I believe Its 39 lbs. Pack It double tripple packing, It will be Dropped.Shipping would be around $55 to 60 the thing is heavy. Let me know if that is ok. and what is a fair price for the gear box?
A picture would be great and yes It is yours.I need a VSS. It's the speed sensor on the tail end of the transfer case. I can send you a pic if you like. Let me know if you have one and hoe much. Thanks.
Copy that.I believe Its 39 lbs. Pack It double tripple packing, It will be Dropped.
I'll send it tomorrow.A picture would be great and yes It is yours.
No center caps good OEM rimsDo you have wheel center caps, preferably just need one but would buy all 4 if in good shape. Price with shipping to 99218? Thanks!
I will look.Any chance you have the cap for the rear of the drivers side running board?
I have antenna switch not sure what fender skirt ispassenger side fender skirts and an antenna switch if they are available. Shipped to 43206
I think so I will look today.Any chance you have the cap for the rear of the drivers side running board?
I do have cap for running boardAny chance you have the cap for the rear of the drivers side running board?
have antenna switch in hand it is off a 94 not 93 I can email picture if you want.I have antenna switch not sure what fender skirt is
you want the wire harness that goes from ECU and snakes up front passenger fender to the engine bay?Would you be willing to sell the harness/connector and the ~6" or so of the wiring that connects to the diff lock ECU? Your '95 should also already have it I believe. I don't need the ECU or anything else, just the wiring that connects to the diff lock ECU. Let me know!
I can do that It will be next week I am away for a few days.Yes. Technically I only want part of it--the part that connects to the diff lock ECU. And about 6" of wiring. But whatever works for you as long as that section is included.![]()
