For Sale 1992 fj80 parts (GET EM BEFORE FEEBAY DOES)
Still have most parts!
Got the seat belts yesterday. Thanks for the transaction. Great doing business with you!!
Do you happen to have the little knob that goes up and down on the lift gate lock? Don't know how else to describe it. It is the manual lock knob on the upper portion of the rear gate.
I know the knob, unfortunately I don't have a good one though. Let me know if I can get anything else for you. It was my pleasure! Dale
Still mostly complete.
Have fj80 radiator and/or engine hooks shipped to 97305?
Can send the hooks, but it'll probably be a few days before I can strip them. I put a small hole in the radiators lower bowl upon removal. It could easily be braised, but don't know if that's something you're interested in?
Dale
Hey! Interested in the leather boot on the E brake and the boot / knob on the 4wd shifter & lastly the tailgate lever. Shipped to 81435 email tim@ telluridebytes. com
Thanks!!
Thanks!!
Sent email.
To the top.
To the top
To the top
Still lots left
I still have the following parts for sale. If you need others don't be afraid to ask.
3fe Engine parts:
Engine wiring harness
Head
Thermostat housing
Smog equipment
Water pump
Fan clutch
Oil pump and pick up
Fuel injectors
Fuel injector rail
Belt tensioner assemblies
Belt pulleys
Valve cover
Alternator
Starter
Distributor
Intake manifold and sensors
Exhaust manifolds
Air filter (tuna can)
Complete transmission
Transfer case
Drive shafts
Front, and rear axles
E.c.u.
Main cabin wiring harness
Cruise control actuator
Various modules
Corner marker lights front
Door handles interior/exterior
Grey dash pad without cracks
Good grey passenger front seat
Ragged out drivers seat grey
Sunroof Complete assembly
Antenna (mast is broken at base but works)
Turn signal, headlights, wipers switch assembly.
10 oem aluminum 15" wheels (4 without tires)
Glove box (grey)
Ignition tumbler with one key and electronic components
Door locks (two front) and glove box lock matching set includes one key (no hatch lock).
Instrument panel (gauge cluster)
Mirror switch
Dimmer switch
Rear heater switch
THE BODY AND FRAME ARE GONE.
Thanks for reading! Dale
To the top
Drivers side door panel, any color, don't need switches etc.
