Curtice
HI all - I am putting this engine into my FJ40, but I am trying to understand how to wire the alternator and I want to include the charge warning lamp on my dash. Below is a snapshot of the charging wiring diagram from the 1992 FSM. Can someone help with the following questions:
1) I thought the 3FE came with either a 80 amp alternator or a 90 amp. However, according to this diagram, the charge warning lamp is wired differently depending on if you have a 90 amp or a 60 amp. A 90 amp does not use a relay (Y-W wire directly to warning light) and a 60 amp does apparently. I am not sure which alternator I have and I want to wire it appropriately. I have attached a couple pictures of my alternator if it helps someone help me identify it. Seems like most of these are 80 amp, but that isn't even an option on the wiring diagram...? My cowl harness with fuse and relay box came from a different vehicle. It has the relay, but that doesn’t necessarily mean my engine/alternator did.
2) If I want to replace the charge light relay with a simple aftermarket generic 4 pin relay, I assume it would still work? Or is there something special about the actual charge light relay (now discontinued) that came with the FJ80?
3) Either way, is the relay necessary at all? Why would it be used with the lower amperage alt only? Seems like it would be used on the higher amp version...
thanks much.
thanks much.
