- Thread starter
- #21
I'll run a shipping estimate for you and get that right over. Cheers.I’ll take the “lower dash”plastic,the rubber shifter boots and the under hood fuse box to 98312.
Thank you
Thank you
It looks to be. Mine had an aftermarket switch there. I'll grab a measurementTruck did not have a center console fridge, sorry.
This truck had a switch there (headlight leveler). Is it the same size as a normal switch blank?
Steering wheel was sold.
I'm fairly certain you're looking for part number 5553932010C0. Should be available at any dealer or online parts source. ~$3-5ea.It looks to be. Mine had an aftermarket switch there. I'll grab a measurement
Yup. In my head there was no way that was still produced.I'm fairly certain you're looking for part number 5553932010C0. Should be available at any dealer or online parts source. ~$3-5ea.
Fender flares long rusted off this poor girl.Hello, looking for all fender flares, ignition switch
Thx
Interested to vacuum assist with brake and 12/24 starter relay. PM sent.RHD Lower Dash Panel. $75
RHD Glow Box. $30
RHD Dead Pedal. $15
80 Series Rear Fog Lights. Lenses are a bit dull. $25
RHD Drivers Door Master Switch Panel. Tab is Broken on Rear. $50
Manual Transmission Vacuum Assist Clutch Booster and Master Cylinder. Worked Great. $50
Manual Transmission Master Cylinder. Untested but looks fine. $20
RHD Brake Booster and Master Cylinder. Worked Great. $50
12V/24V Starter Relay. $40
RHD Headlights with built in fog lights and I believe electronic levelers. Light pitting on the glass. All tabs are intact. $250
LHD or RHD?I'm doing a 5spd swap from my auto hdj81. Looking for clutch and brake pedals, clutch master and slave, hard and soft lines, brackets etc. Got any of that stuff left? Also centre shifter console?
I still have the lock set. PMing you.You still got the lock set? I’ll take it all as one if you do?
Also front marker lights? (Bolt to headlights)
No sorry. That went immediately with the clutch pedal.Do you still have the clutch pedal firewall bracket?
