For Sale 1990 HDJ80 Part Out RHD JDM 1/25 Price Drops
I’ll take the “lower dash”plastic,the rubber shifter boots and the under hood fuse box to 98312.
Thank you
I'll run a shipping estimate for you and get that right over. Cheers.
Truck did not have a center console fridge, sorry.
This truck had a switch there (headlight leveler). Is it the same size as a normal switch blank?
Steering wheel was sold.
It looks to be. Mine had an aftermarket switch there. I'll grab a measurement
I'm fairly certain you're looking for part number 5553932010C0. Should be available at any dealer or online parts source. ~$3-5ea.
Yup. In my head there was no way that was still produced.
Thanks.
RHD Lower Dash Panel. $75
RHD Glow Box. $30
RHD Dead Pedal. $15
80 Series Rear Fog Lights. Lenses are a bit dull. $25
RHD Drivers Door Master Switch Panel. Tab is Broken on Rear. $50
Manual Transmission Vacuum Assist Clutch Booster and Master Cylinder. Worked Great. $50
Manual Transmission Master Cylinder. Untested but looks fine. $20
RHD Brake Booster and Master Cylinder. Worked Great. $50
12V/24V Starter Relay. $40
RHD Headlights with built in fog lights and I believe electronic levelers. Light pitting on the glass. All tabs are intact. $250
Interested to vacuum assist with brake and 12/24 starter relay. PM sent.
I'm doing a 5spd swap from my auto hdj81. Looking for clutch and brake pedals, clutch master and slave, hard and soft lines, brackets etc. Got any of that stuff left? Also centre shifter console?
LHD or RHD?
You still got the lock set? I’ll take it all as one if you do?
Also front marker lights? (Bolt to headlights)
I still have the lock set. PMing you.
Corner lights were trashed.
