I've recently started getting some hesitation in my truck. It happens at all speeds and especially uphill. Feels like it isn't getting fuel, then all of a sudden will burst, then hesitate, then burst again. If I stomp on it, it'll level out until I let off.
1. I'm losing an overflow bottle's worth of coolant every three fill ups or about once a month. No "milkshake" in the oil.
2. I just changed the fuel filter under the hood.
3. It is NOT currently holding any codes, as I just replaced the alternator and the battery was disconnected for a couple of days, but about a month ago, it threw 25 and 26 consecutively, but then the CEL went out the next time I cranked her up.
4. I did a compression test yesterday and my numbers were 142, 122, 140, 120, 130, and 120. I'd like them to be more consistent, but they're not out of spec.
5. Injectors were recently sent out for cleaning, so I don't think those are the culprits.
6. I put a vacuum gauge on it and it hangs out right at 19, then misses and falls to 17, then comes back to 19 and stays. Revving the engine does all of the normal things that you'd expect from a good vacuum test. (I'll post video later)
7. Checked plugs and wires during compression test. All looked fine, although #3 had just a little oil on the threads. All were pretty close to correct gapping.
8. Cats are cored out.
9. Idles perfectly at 650, except for an intermittent miss.
10. I have an exhaust leak around both cats.
Any thoughts on what else to check?
