SOLD 1985 Toyota 4-Runner Highway Worthy Crawler
General Description:
1985 4-Runner, Fuel Injected, with Marlin Crawler drive train and Matching Trailer. This is Not a project, but a Highway and Trail Ready rig. I have owned tis rig many years, it simply isn't getting the use it should any more, am focusing more now on my 2- FJ40s
  • Runs and drives well on and off road. Drives well at highway speeds, and often gets better than 20mpg when not pulling the trailer.
  • Has no rust, AZ and Cal truck
  • Has cold AC
  • Over 23K in receipts (have all receipts)
  • Only OEM parts used when available
  • All custom work professionally done
  • Owned and maintained by Toyota Master Technician.
  • Custom removable tube doors and hinges from 4x Innovations and comes with original doors.
  • Soft Top from SofTopper, can be rolled up for upper shade only, and can be folded back into carry case, full convertible, and comes with original hard-top
  • Trailer professionally built from a Toyota Pickup bed, with a true trailer axle, and sway bar. Has custom Jerry can holders on the front of the trailer.
Suspension & Drive Train:
  • MCTM-1W56A HD V6 5spd Transmission built by Marlin Crawler INC
  • MCTC-141 21 spline Dual Transfer Case Ultimate Kit with a 2.28-1 ratio in the front box, and 4.7-1 ratio in the second. Has a total of 20 forward gears, 4 reverse, and lowest gear is 500-1 ratio.
  • Complete Chromoly front axle and knuckle kit from Marlin Crawler
  • Front and Rear Axle Trussed, with High-Pinion V6 front carrier, and V6 Turbo rear carrier. Built by JC Fab and Design with 5.29 Yukon gears and Detroit lockers.
  • Custom front and rear Drive Shafts built by Simmons Automotive.
  • Warn Premium M8000 winch
  • Late model steering gear box and required modifications for installation, Forged High-Steer steering kit, 23mm tie rods and steering linkages, U-bolt flip kits front and rear, and High Hoop shock mounts, and rock sliders by All-Pro Off-Road
  • Front springs are the original springs from the rear, and rear springs are 62" Chevy springs. Front springs are moved 1.5" forward
  • Bilstein Shocks
  • Front fenders and spring shackles by Downey Offroad
Engine
  • 62,000 miles on prof. built 22re short block by Platinum Auto Repair, Toyota and Lexus Specialists.
  • Less than 10,000 miles on Street RV head from Engine Parts Network, with oversized SS Valves, and upgraded valve springs.
  • Late-model Fuel Injection intake and throttle body
  • EPN HP272-110 Cam
  • LC Engineering Street Header
  • Aluminum Radiator
  • Black Magic #674 electric cooling fan with controls
  • New Mass Air Flow Meter
Loose Parts:
  • Complete Dual Battery set up, including battery tray, harness, and Isolator, minus battery
  • Extra new Alternator
  • Original fan, shroud, and hardware
  • Original Exhaust Manifold and Intake Manifold
  • HL-605 HIgh LIft Jack
  • 30" Nitrogen bottle with 30' air hose
  • Power Inverter
Other Information:
  • Tires about 80% tread
  • Interior has flaws, imperfections in front and rear seats, distressed shifter boot
  • The paint is in overall good condition, but has some variations in color, and trailer is not an exact color match, but matches much better than the pictures indicate. They look almost the same color in person. I use the same touch-up paint on both. The rig has been on the trail several times, and has several dings here and there, and many touched-up rock chips in the paint. There is a small dent beneath one of the Marlin Crawler stickers, and the trailer has a couple small dents in the body.
Price: $23,900
Phone number: 520-508-3654 call/text
Can e-mail additional photos if requested.
If anyone is seriously interested, I can do a PPI for them for the price of gas. :)
Thanks acoen, it was carefully planned and I'm really happy with how it turned out. I wish I used it as much as I planned to when I built it. What I didn't expect is how well it drives on the highway after all the mods. This thing actually drives as good or better than it did stock on the highway, not to mention it's off road capabilities, and gets nearly the same gas mileage.
Hey, thanks. What gears are you running with the 35s? On mine, the 529s seem to be a perfect match for the 35s. Speedo is accurate without any changes to the speedo gear. I got lucky with that combo.
I am running 4.88's and like it. I have a engine from 22RE performance and went with a low-mid cam which works great in the 1,000-3,000 RPM range but doesn't pull like the mid range performance cam I used to run. That said it lumbers along in the 2400-2800 range great. Still need to down shift on long grades though. But is turning good millage running the new BFG KM3's.
I also have 4.88's in my truck and absolutely love it. I'm on 33's but I average 18-19 MPG too.
I'm no longer receiving e-mail notifications when someone posts, so feel free to call if you do not receive a response.
Thanks
Nice rig
Sorry for the slow responses guys, for some reason I do not get e-mail notices anymore when folks post, and I'm not on the forum very often.
Smog:
Everything is in tact and functional except it currently has the LC Engineering cat delete, but believe I still have the cat in the box of parts that go with the truck, if not, can easily come up with one. It should be a simple bolt in.
Nice Rig:
Thanks!!
