3FE Things
My truck started running really rich recently and afterfiring, A LOT. I "scanned" it and the ECU revealed a code #22, indicating a fault in the coolant temp sensor or circuit. I replaced the connector going to the sensor as a first step because I knew that it was very degraded being 1988 plastic and wasn't clicking onto the sensor properly. This did not resolve the issue, I replaced the sensor with a Japanese Tama unit next, no change. The truck was still running rich and was actually shooting flames out the exhaust a couple of times when I downshifted going uphill. I then swapped out my ECU for a spare and the code is gone, and my truck isn't shooting flames anymore.
I'll split my ECU apart and see if I can see anything on the board.
I'm still getting very poor fuel mileage. 10-11 MPG. Before I put my 255/85r16s on I was averaging between 13-14 MPG. I don't believe the tires knocked down my mileage that much, so I will continue to do some further diagnostics and see if I can determine why fuel economy is so poor. I will probably check timing as a first step, as well as swap out my fuel filter as it's been probably five years since it was replaced last.
