Hi Guys, ( already searched )
I have a 83 pickup, the trucks previous owner wasn't much of a mechanic and did more harm then good. I have been taking my time going over the truck and trying to piece Togother the wiring that was hacked and redo the vaccum lines. I have a FSM for 83 so i am pretty sure everything is going correctly.
My major problem is that the truck will not start but it will run. It was going good till i had to replace the origional carb when a seal in the carb went. I had a 85 carb that had been recently rebuilt, given to me. My truck was missing the plug for the 85's electric parts on the carb. I have them wired temporarily to run the eninge (the red wire to the choke is hot and should be on when the ignition is on, and off when the key is out. I already know that.). So what happens is the truck wont kick off on its own. Fuel has to be sprayed down the butterflies of the carb to get the engine to kick over. Once it has been running for a few seconds the fuel pump will supply the carb just fine. It just wont start on its own. Even after the engine has run if it is shut down it will not just fire up with out spraying fuel in there. I am betting there is something wrong with either vaccum to the carb. Or (not sure if this is correct.) if the accelertor pump is dead it will not work.My knowledge of these things is limited so any informaton you can give me would be great.
I do know for certain that it is not a case of a plugged fuel filter and im getting good spark.
- Jason
- Jason
