1982 FJ40 wire harness
Helena MT
this came out of an 82 FJ40, no a/c, no PS $350. or offers plus shipping located in Helena MT
part #'s 82215 90802C goes between the seats
82370 90801 goes to wiper motor
82420 90805C rear harness
82210 90822A front pass side
82220 ????? cowl with switches and fuse block
a few more pics, only damage is the wires going to the radio, last pic.
this is still available, all factory connectors, easy install.
did I get it from you? by memory I wouldve said shmukster
years ago we traded some stuff around.
PM your address, I have something to send you.
Paul
I have a perfect 81 harness on the shelf if pics of something there would help
Hi
I Would be Extremely great-full For some good pics of the wiper sub harness that goes from motor , through glove box , then connects behind ash tray into the main harness ......
the 4 color code tracer stripe wires locations terminals at motor
- i think the single connector housing First gen micro spade connector with 2 x 4 opposing terminals ?
- the pro date transition is 1/75 6/80 & 7/80- later so a 1981 should be the ticket .........!
- if the plastic white parts tag is still intact & not long since crisped away to dust is should have printed on it something very close to this : 82370 90801
thanks
i have 100% intact for reference photo sharing as well :
- 75 - 76 FJ55 entire complete usa spec harness all sections including 82210-90389 82420-90354 A tags
- 1977 FJ40 usa spec complete intact . Minus the Rear tail lamps rear markets section
@RAGINGMATT ,
@Coolerman was able to build a wiper harness for me - 1980 FJ40. Check with him, I'm sure he has pics. If I remember correctly, the under dash part is 4 separate bullet connectors - and I don't think all 4 of the connectors are in the same place on the harness, maybe 8 10 inches apart in terms of where they exit the harness. 2 connectors in one place & 2 in another.
Hope that helps.
