- Location
- United States
Looking for a 1979-1983 Fj40 fan shroud. They are about 1 inch wider than the 1978 and earlier models. If you have one let me know.
AC version
SOR is the last option.good luck, try SOR?
I have a couple regular shrouds that are in great shape. I didn't want to cut those, I thought about it though.when I was giving dimensions to another mudder, all the extra length is gained on the passenger side of the shroud.
can't remember the exact amount.
the fan opening is in the same place, either a/c or non a/c version.
wondering if you had 2 non a/c units, if they could be grafted together???
Since the fan opening is the same, a metal strap on each side to span the gap to the core support would be the non-invasive solution. I even have some metal strap laying around that would work if you want to try it.
Thanks for the reply. I found one, and it was not easy.I have a shroud. Not sure what year it’s from. Bought from another mudder. Do you have the demensions that your looking for and I can check?
