SOLD 1977 FJ55 Heater/'fresh air' air duct triangle....Jacksonville 32207
DIS TING???
Life got in the way today,,,, re the pic... my larger rectangle duct is ok, but the rectangle turns into a triangle at the heater box, and there is a rectangle piece maybe 2-4 inches in width that joins the heater to the duct...
Maybe I'm wrong! It looks as if there is a connector piece between the air duct and the heater box, like a collar... I need to get a good look at it again.. I had it apart about 6 mos ago and realized the collar was cracked/repaired previously.. I'm 70 so gotta check myself! Grins...
It is.. It's the 'sleeve' at the front of the third pic that appears bent... If it's available I'm in... thought is I'll use a heat gun and reshape... Let me know $'s .. or the entire duct... thanks
Rick
I'm in need of the triangle plastic connector that joins the front heater box to the fresh air supply channel...
Not certain of the years, but SOR shows 74-80...
I have one. Plastic is in good condition. No cracks. The rubber coupling part is not so good.
