For Sale 1976 Built K5 Blazer: Street/Rock Crawler-Bay Area, CA LOWERED PRICE 10.5K!!!
1976 Built K5 Blazer: Street/Rock Crawler-Bay Area, CA SOLD................!
SOLD...........................
Owned this rig for 26 years….built to drive to the trail …from the mountains to the desert in all types of weather...wheel all day, camp…and take you/family/friends back home safely…..Never thrashed, always maintained using quality parts and EXTREMLY RELIABLE…….
One of a kind....
MOTOR:
350 Good wrench 4 bolt main, RV Comp cam, Edelbrock 670 cfm quadrajet carb recently rebuilt by Nor Cal Carbs, K&N filter/pre-filter, steel braided fuel lines , new fuel pump, Powermaster 140 amp alternator, dual batteries, MSD billet distributor, 8.8mm plug wires, Royal Purple 10-30w synthetic oil, Have ALL smog equipment (passes smog even w/o smog equipment) brand new 4 core [COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]radiator[/FONT][/FONT][/COLOR][/COLOR], Flex-a-light dual electric fans with “turn on/off sensors” at 190-205 degrees f w/override switch, custom aluminum shroud, …….~75k miles….always reliable, never overheats and runs perfect…..
TRANSMISSION:
Turbo 350 with B&M shift kit built by J&M Trans in Tracy….Royal Purple fluid, shifts great. 1 ton trans. cooler , Derale 8” electric fan with on/off sensors and override switch….
[COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]TRANSFER [/FONT][/FONT][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]CASE[/FONT][/COLOR][/FONT][/COLOR][/COLOR]/SKID PLATE:
203/205 4:1 Doubler built by Off Road Design, triple stick shifters, custom made full skid plate/cross member..
DRIVELINES:
High Angle Drivelines, CV’s w/1350 Yokes, Great Lakes yoke girdles.
[COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]FRONT [/FONT][/FONT][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]AXLE[/FONT][/COLOR][/FONT][/COLOR][/COLOR]/STEERING:
DANA 60, 35 spline outers w/ 1 Ton Warn hubs, Stage 8 X Lock spindle nuts, 4:56 gears, Detroit Locker, DIY diff cover, new [COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]wheel [/FONT][/FONT][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]bearings[/FONT][/COLOR][/FONT][/COLOR][/COLOR]. Borgenson steering shaft, 2 wd tapped steering box, reinforced frame, PSC Ram assist, high steer w/tie rod behind axle, new TRE’s, Parts Mike springless steering arms w/ARP Studs (no death wobble), stainless steel braided brake lines….
[COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]REAR [/FONT][/FONT][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]AXLE[/FONT][/COLOR][/FONT][/COLOR][/COLOR]:
Corporate 14 Bolt, 4:56 gears, Detroit Locker, disk brakes w/wildwood proportioning valve, stainless steel braided brake lines, truss, custom trac bar w/ shackle and cross member, pinion guard, Dynatrac diff cover, royal purple fluid.
SUSPENSION:
FRONT: Recent 6” 8 leaf Alcan springs, new Pro-thane [COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]bushings[/FONT][/FONT][/COLOR][/COLOR], DIY 6” shackles, bump stops, Bilstein 5150 14” Shocks, custom shock hoops/tower tied together.
REAR: New 5” 8 leaf Alcan springs, new Pro-thane [COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]bushings[/FONT][/FONT][/COLOR][/COLOR], DIY 7” Shackles, bump stops, custom inboard shock mount, Bilstein 5150 12” Shocks.
TIRES/WHEELS:
4 BFG KM2 (80% tread) 38x16 mounted on 16x10 black steel plus 1 brand new spare, transferable full warranty from 4wheel parts on ALL 5 tires.
BODY ARMOUR/BODY:
Custom [COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]front [/FONT][/FONT][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]bumper[/FONT][/COLOR][/FONT][/COLOR][/COLOR] w/warn 8274 winch wired in-cab, 3HID’s mounted on light bar, HID Fog Lights, 2 D Rings, 12v receptacle….…
Custom [COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]rear [/FONT][/FONT][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]bumper[/FONT][/COLOR][/FONT][/COLOR][/COLOR] w/swing out rear spare tire mount, 2 rear halogen lights, 2 D ring mounts, receiver hitch , 12v receptacle, rock sliders, storage box’s, shovel/axe mount s.
Custom half doors w/aluminum diamond plate, rino-lined, soft doors w/new plastic windows, comes with full doors as well, foldable YJ rear view mirrors…
BESTSTOP soft top, vinyl half top, and OEM fiberglass top…
HID driving lights, LED parking and rear [COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]brake[/FONT][/FONT][/COLOR][/COLOR] lights, 8 LED rock lights, 5 amber cab lights, 4 Genright hood vents….Body painted in desert camo, has typical wheeling dings, dents….
INTERIOR:
Custom full family roll cage, front seats from a 2000 dodge truck w/huge [COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]center [/FONT][/FONT][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]console[/FONT][/COLOR][/FONT][/COLOR][/COLOR], full Auto-Meter pro-comp gauges mounted on custom aluminum dash, custom fit Tuffy overhead console houses light switches, Sony Xplod stereo w/6 speakers, Cobra CB and speaker, 12v receptacle, 1500w inverter, VIAIR 500 air compressor with 2-2.5 gallon tanks plumbed to front/[COLOR=#fff200 !important][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]rear [/FONT][/FONT][FONT=inherit !important][COLOR=#fff200 !important][FONT=inherit !important]bumpers[/FONT][/COLOR][/FONT][/COLOR][/COLOR],
Roof rack and CO2 mount not included...
NEW LOWER PRICE: $9 K…..<><
Email: pastorisi@yahoo.com
Bay Area, California
http://i953.photobucket.com/albums/ae13/highandliftedup/76 K5 FOR SALE/rubicon2010cadillachill.jpg
pics:
http://s953.photobucket.com/albums/a...%20FOR%20SALE/
Pretty sick rig! GLWS.
-Daniel
Lowered price
Before the great American Chevy k5 part out...........price lowered to.......................... $9k..........
Whoop!
-Daniel Kent
