- Thread starter
- #21
1973 fj-40
I have a list of leftover parts from my restoration about 10 years ago.
All used unless noted
All from a 1973 fj-40
7" round headlights sealed halogen-$15ea
front fender mount turn signal units used (pair)-$25
Misc horns. 2 stock, other models.$5 - SOLD
Stock round side mirrors with brackets and arms-$50 pair - SOLD
driver side frame mount splash guard-$10- SOLD
hood latches -used (pair)-$10 - SOLD
Side engine remote oil pressure housing-$10
upper & lower thermostat housing-$30 - SOLD
thermostat-$20
rear Toyota emblem-$10 - SOLD
rear 4WD emblem-$10 - SOLD
engine oil dip stick-$10
clutch cylinder and slave cylinder-$40
brake cylinders 8 ea-$60 all
stock alternator-$75
brake cylinder - stock-$25
brake cylinder - aftermarket new. never mounted-$50
stock air cleaner-$75 - SOLD
fuel hard lines_$10
NAPA brand starter-$50
stock distributer-$75
stock carb - missing some pieces-$75
carb linkage plate-$25 - SOLD
fuel pump-$75
smog pump , bypass pump, misc smog hoses-$100-all
timing gear w/ camshaft-$50
old man emu nitro shocks 2 ea-$25 both
coil over shocks 2 ea-$25 both
rear bumberette 2 ea-$40 pair
rear tow ball drop plate-$10
intake and exhaust manifold-$250
intake only manifold-$150
Let me know if any more pics or information is needed.
Located in the Sacramento, Ca. area.
View attachment 1740704 View attachment 1740708 View attachment 1740709 View attachment 1740710
@3_puppies I chose that air cleaner partially because you asked me about the dual snorkel. Here’s another shot of one mounted on my ‘64... just because it’s something different.
As resellers, I wouldn’t mind having your opinion, as well as @pardion on the condition of the part I purchased.View attachment 1751067
@65swb45 Seeing this photo of the inside and the top rim of the air cleaner showed me this is not a serviceable part, a reminder when selling to inspect parts fully before putting on a value and selling. I would ask the seller for a full refund. Or supply a non repaired good bottom air cleaner can. John
I’m interested in the air intake. Which month was the ‘73 this came off? I’m looking to replace the cracked intake on my 12/74 F155
