- Year
- 1969
- Vehicle Model
- 55 Series
- Mileage
- 81000
- Color
- hsl(0, 2%, 27%)
- Outside Link
- https://www.facebook.com/share/176R3aUyyM/
Engine runs real good. Driver side exhaust manifold is off while I build the other side pipe and finish the shifter install. Some highlights. 81,000 original mile, Box A title. Sat for almost it's entire life.
92 LS400 1UZFE engine, A340F 4runner transmission, brand new 0 miles skyjacker Nitro8000s on all 4 corners, 60 miles on the mickey thompson baja legend 31x10.50r15 matching set of 5, braided stainless brake lines converter to AN3, custom made 37 gallon fuel tank, 044 fuel pump, tuned on a Megasquirt gold box standalone ECU, spring over lift, roll caged, 13,500lb winch with synthetic line never been used only mounted and tested, custom built Gamiviti roof rack with 4 -7" round lights and 4 - 4x2" light bars that point to the sides and backwards, 270° awning with built in lighting, LED headlights, RADesigns VX Control standalone shifter and shift controller, there's just so much stuff to list.
CONS. I did not weld the winch plate in completely, it's tacked in place. Same with the spring over, the plates are all tacked. The seats are a little worn out. I bandaid fixed the passenger front door hinge but all doors work. shifter not wired or mounted. need to make a tcase shifter.
I have the rear glass but no motor for it. Considering partial trades for wood truck plus cash - Dodge, internationals or Toyotas. Video of it running on the external link, or you can view my build thread in my signature.
13k obo.
13k obo.
