Mike, unbelievable build man. Pete down here in Sacramento. I need to stop by sometime after the waterfowl season.....My 45 is coming along, but no where near this level....Nice Work...!!
miker said:Yep, those were made with a hacksaw. I actually do quite a bit of cutting with a hacksaw. If you have a good frame, and purchase good quality blades (I like Starrett - the yellow ones, 18 TPI) then you can make nice straight cuts, and pretty fast too in 1/8 to 1/4 thick steel which is the majority of what I'm using. The other benefit is it that adds to your days cardio minutes.
At first I was keeping a separate wheel for grinding just the tungston but then I started using whatever was handy and I haven't noticed any issues. When I start working with aluminum, then I'll probably have to be more careful about keeping things separate.
I've heard too that if you want to switch to aluminum with the same tungston, all you need to do is to strike an arc onto some copper for few seconds and let any impurities burn off before starting to weld on aluminum. Haven't welded any aluminum yet so I have no experience with this. I still plan to make the gas tank from aluminum so I will need to learn. I'm using the type of tungston that works for both carbon steel and aluminum so I might give this copper thing a try. The tungstons are not very expensive in the whole scheme of things so having dedicated ones is no big deal either.
The quickest way I've found to grind the tungston and get great results is to chuck the tungston into a battery powered drill. Then use this to spin the tungston, then while its spinning, move it against the grinding wheel. Fast and accurate. Arc from the tungston is nice and predictable.
Hi Mike,
Things are looking sweet. For welding aluminum you want to use the pure tungsten ( green band on it) and AC current. Aluminum takes a lot more heat than steel. If you get much more than 1/8 material your torch will heat up pretty hot. I use a water cooled torch at work for any heavy stuff. I don't sharpen the pure tungsten, it will form a ball on its own when using AC.
For carbon steel or stainless the 2% thoriated tungsten ( red band) and sharpened works best.
Just remember to use the end of the tungsten that is not painted so you can always tell what it is later
If I can help you out with any of this stuff let me know.
Sent from my ADR6400L using IH8MUD
hey Gus,Mike,
Are those the original stock (45) springs you painted?
I'd really value your opinion at some point on what I should do with my 40's suspension - which seems to have old PO installed Rancho springs, a weird mix of shackles, and misc. hardware. I'm thinking a complete OME package but wondering if it's really the way to go for a "quality", moderate stock type setup?
If I could get stock springs from Toyota I'd go that route. A guy at SOR told me I could just buy their springs and use stock Toyota stuff? And then there's Alcan, etc.
Just wondering what you would do.
Thanks,
Gus
)Here's a better shot of the gap between the hanger and the frame. This is where I'll have to make a shim/spacer to keep from damaging the hanger once I put in that last bolt and tighten it up.
the bleeder is supposed to be up. Its up on mine as well.
yea. ThanksI guess I was confused, that is good to know. It has been a long time since I did that part of the build. Body is going on the frame soon thou.yea. Thanks
Sounds like you are much futher along with your build than I am.
I don't have a good indide pic of the bleeder, but first one is a pic looking down. You can see the bleeder on the lower left. Second pic from the outside showing the caliper, but the bleeder is hidden.
