17mm IP bolts
Somewhere with some sort of Cruiser
How are you guys access the 17mm rear bolts on the IP pump? This is on a 1hdft
I already had to order a longer 12mm box wrench to the get the front 12mm nut loose closer to the engine. Now I am scratching my head on how to get the rear 17mm bolts loose.
I have taken the passenger (right side) tire of to see if I can get it from there--I think this is the route I will need to go, but wanted to post up first.
Cheers,
Michael
Never Mind, was able to get it with a 12 point socket and swivel socket. Which I normally never use!
