16" or 17" wheels
lumbee1
Native American
Holly Springs, NC
The Cruiser originally came with nice cast (some say forged) wheels which limit the tire size to 35". I know there are 37's for 16" wheels but they are very limited and expensive.
17" wheels have become the small wheel / big tire standard and there are some manufacturers coming out with new tires that don't even support 16" wheels.
I'm debating whether to start saving pennies to replace my OEM wheels or run what I got until tires for the 16" wheels are almost non-existant.
Thoughts?
If you can find a tire you like that'll fit the 16's, no sense changing things up now. If you can't, then look at 17's. I spent some time a while back looking at and researching every 35-ish inch tall tire that fit a 16 and 17, and ended up with 255/85-17 Mickey Thompson Baja Bosses on first gen Sequoia wheels. There were several factors that went into landing on the Sequoia wheels. They're dirt cheap, are very easy to find, and they're narrow enough for the pizza cutters.
Anyway... yeah, I think the 16" tires are going the way the 15" tires went.
Over here I couldn't find any 315/75r16s anymore or only China made.
Largest I could find is 285/75r16. Since it's an 80 series, obviously 35s are the bare minimum.
Switched to Braid Winrace Ts + 315/70r17 Kumho At52.
Sure 315/75r16 look better on factory wheels but seems those days are numbered.
Bad pic but you get the idea
I'm interested in the new Toyo RT Pro and it starts at 17" and goes up.
I’m in the same boat. Still looking for good looking 17” wheels that are the correct width and offset and easy to find replacements if needed. I’m worried aftermarket wheels could be a hit or miss as far as buying replacements. They’re here one day and gone the next. That’s why I’m kinda set on OEM wheels l. You know if you need to replace a wheel you can still hunt down a used one on eBay or other sites. Once they discontinue a certain aftermarket wheel you’re kinda screwed.
You speak the truth. I don't think I've seen anyone kill a OEM 80 series wheel.
I'm looking at Nomad, SCS, and SSW at the moment. But when these styles are no longer desirable and I need a replacement, do I have to get 5 new wheels?
I'm running 35" Toyo RT Pro on 17" wheels and love the set up. The tires are as quiet as any AT I've run, and much more aggressive off road. They also look awesome :cool: Highly recommend.
I've got Cooper ST Maxx on the Cruiser now and while they are good on-road, their offroad performance is not that great. I find myself slipping and sliding quite a bit more with them even with descent tread and air'ed down to 17 and 18psi. In mud, they are the worst.
From my research, most Toyota OEM 17" wheels are going to be found on IFS rigs, and they're mostly 7.5" wide but a few are 7", and all have 15mm offset. FJC's are where you'll find the steelies if that's what you're after. Otherwise, you have quite a few alloy wheel designs/styles to pick from. Newer Tacomas ('24+, I think) have a smaller bore and a ton of offset and won't work. FWIW, 1G Sequoia/Tundra 17" split five spoke wheels go for $50-$70 around here and are all over every junk yard I've rooted through.
A reference guide to wheel and tire sizes for your car - https://www.wheel-size.com/ is a great resource for OEM wheel specs.
Nice, thanks for the review. I've wondered about those as well. I love their AT (for a truck that sees mostly on-road use with occasional logging roads, etc), but I was pretty unimpressed with their first gen mud terrain. I'll probably go up to 37s for my next set, and those look like they might be just the ticket.
That was part of my reason for going the Visions: I wanted something with around zero offset like the OEM 16s, not 15mm inward like IFS wheels and not sticking out an extra inch like most aftermarket stuff. I do love the look of those Sequoia/Tundra wheels. Right up with the 80 wheels for some of Toyota's best looking factory wheel.
