13bt water pump removal
Clutchee
I'm fun sized!
Hotel M-F, home weekends!
Folks on my 1986,BJ 71 doing maintenance and was replacing water pump…. How the heck do I get it out?
All bolts removed and hoses…. Vertically goes up but then stops.
Any tricks or tips folks may know?
Help appreciated.
I had to remove the thermostat housing, and possibly one bolt on the power steering pump before mine would come out.
Thank you sir!
In the am, I’ll try that.
Mine's removed...
Replacing it... that's another fun game - my advantage is my engine is out at the moment!
Folks quick update, removed 2 of the power steering bolts, third one was loose.
Then I was able to pry pump towards outside and allowed the pump to come out.
Also removed the thermostat housing upper and lower.
I will say, it was tough but the bolts on PS and the thermostat housing made it easier.
@Clutchee I am in the exact same situation as you were, struggling to remove water pump on 13BT engine in my BJ71.
Any chance you took photos of the power steering bolts you needed to remove? I am trying to locate them but this is first time doing this on 13BT and having some trouble orienting myself? This isn't my forte ...
Glad to help…. Look at circle.
Where this mount is, behind it is 3 bolts holding it to the block. I took 2 fully out and left one still threaded but very loose.
Thanks so much - I know what I'll be doing tomorrow after work.
