hi have recently put my engine (13bt) back in truck and it is blowing lots of black smoke when changing gears and reving it. Im thought it used to run higher boost before i removed it. Now it only running 8psi I have checked fuel filter in fuel feed pump , i have checked intake for any obstructions and both are fine . the truck used to go alot better than it does now. Would stuffed injectors mean more fuel not getting combusted resulting in turbo no being able to create more psi ? It just weird becasue last time i used it b4 removing engine it was goin way better
