Not needing the rear screens, I decided to go with the Victory 4x4 rear screen delete panels. I found some low profile USB plugs that fit nicely with a bit of cutting into the panels.
I laid out the cut lines on the back of the panels, drilled the 4 corners with an 1/8” drill bit, then cut the center out using a pneumatic pencil grinder (air powered Dremel tool) with a cut off wheel. Once cut, I installed the USB adapters.
My plan is to use the 25a seat heater control wire at the base of the seat. I’ll add more once I actually make that connection. For now, they are not powered and just installed to keep the hole closed up.
Thanks to @bhakjdlmn1 for the seat heater wire diagram. If anyone has the diagram for the seat position controls, I’d love to see it. That might be a safer wire to use since its use would be limited while driving.
