so this issue continues to befuddle me. none, NONE, of my plugs work. not the cig lighter, the front console, inside the center console, or the cargo area plug. I got a voltmeter and did some testing... results as follow. The car was running during these measurements.
I started under the hood in the fuse boxes...
I tested the voltage in the ACC relay, there were 12v across the closer two plugs, no voltage across the more separated plugs. The relay itself had no resistance between the closer prongs, and full resistance between the more separated prongs.
The 50A ACC fuse is also good, but there was no voltage across the prongs...
I then moved to the left kick panel fuse box. Fuse 21 for the cigar lighter and radio was good and there was 12v across it. Fuse 39 was good also, but there was no voltage across it. I had a charger plugged in to make sure it would draw current if possible.
Am I missing something? What is supposed to go in the plug I have circled in the last pic? Any ideas on what to do next? Thanks in advance
