You can weld a bung anywhere on your downside exhaust some where in the middle after turbo
A Wideband is not specific to Vehicle
Or you can use a clamp on solution they make different sizes. Many companies to choose from.
1-3/4"-2" Clamp-On Wideband Oxygen Sensor Bung Adapter - https://www.glowshiftdirect.com/1-3-4-2-clamp-on-wideband-oxygen-sensor-bung-adapter/
I like Banks power so I’m planing to get there idash datamonster with no OBD support. Because it’s a multi gauge and has data logging on a SD card. But I like the idea of having egt/boost/oil temps and more in one gauge.
But glowshift and AEM make a o2 Wideband
Inovative motor sports also has a clip on solution you clip on your tail pipe and u can use to dyno tune. It’s more of a temporary install use.
Pretty sure any gauge will do. As long as it’s a Bosch lsu 4.9 Wideband sensor.
