Damn, you only have 400-500K miles left before you might need to overhaul that bad boy![]()
Hoping for something like that here too.......
What happens when the O2 sensors go bad? Right now I'm having trouble with my 98 LC that I think might be the front O2 sensors. After I've been driving for an hour or so I start having trouble accelerating then maintaining speed because the throttle stops responding. Eventually she'll just slow to a stop and I have to pull over and she'll just cut off. The weird part is that I can start her right back up and she'll go fine for a bit. This started happening every once in a while and now is more frequent. My girlfriend was driving her for a couple of weeks and I know she put regular gas in a couple of times when I always put premium in. I don't know if that would have anything to do with it.
Thanks for any help you can provide. Figured I'd run it by you guys before taking it to the stealer.
Dean
What are the odds of improving the mpg with a plug and or 02 sensor replacement?
Not much based on the board reports. Most report zero change. Might try unselecting the ECT PWR button or a more moderate use of the skinny pedal.Maybe some "Sounds of the Ocean" tapes.
120k is recommended plug change milage. Do you still have the original OEM plugs ? Perhaps they were changed out early for inferior plugs ? If so then I would change them out for the OEM from cruiserdan or Denso. Are you calculating milage correctly and making adjustments for your tires ect...
This baby is a mall cruiser.
