1" Trail Gear wheel spacers cover wheel studs?
You can just remove to dome heads and they should clear. I have 1.25 wheel spacers that clear fine.
To clarify:
The spacers bolt to the stock studs.
Those studs have some length (stick out).
If the stud stick out is longer than the thickness of the spacer then the stud will stick out past the spacer and interfere with the wheel when you try to bolt it to the spacer.
1" spacers require cutting about .5" off of front studs. The rear will clear just barley.
