1 offset wheel work for LX 570? (1 Viewer)
Bainbridge Island, WA
I’m wanting to replace some 20” wheels with 18”. Found a set of aftermarket 18x9 wheels that came off a tundra but they say the offset is 1.
I’ll want to put 295x70x18 tires in it so I’ll be putting on spacers probably too.
Haven’t been able to find anything about a 1 offset in the search so thought I would see if anyone knew.
Appreciate the time.
Which wheels are you looking at picking up? An offset that low is going to be tough to squeeze in a 295/70r18 without a ton of cutting of the fender liner and and you'll more then likely be hitting the body mount at the rear of the front wheel well. Stick with an offset between 25mm-40mm for better results.
You are gonna get a lot of hate from the guys here for running 18x9 +1mm even without spacers.
Here's a thread that has around the sizes you are looking for. Should give an idea of what it'll look like without spacers.
Yeah, keep coming across these aftermarket tundra wheels with a 1 offset, had a feeling they wouldn’t work.
All good! Back to the hunt! Thank you guys.
Yeah that will have a good bit of poke and rub a lot. I'd try not to go lower than +25 offset
Are we sure it’s 1mm? Not 1”?
